Go Back   FourWheelForum > Website News & Updates > Motorcycle Parts Wanted
Unread 12-06-2011, 06:09 AM
DanUhr DanUhr is offline
Default CA92/CA95 Clutch thrust washer
I'm looking for a CA92/CA95 washer C, thrust 20mm
PN C902878 or 90453-200-000
It is supposed to be installed between the outer and center clutch.
It's in the parts book page 54 as item #13.
Does any one have the part to sell me?
Is it ok to install a standard washer? If so what is the thickness of the washer?
Dan U
Unread 12-06-2011, 09:11 PM
I'll check in the morning and see what I have.
Unread 12-07-2011, 05:23 PM
65ca95 65ca95 is offline
Check here if Smithers hasn't got one
http://www.atvhondaparts.com/fiche_s...=90453-200-000
Unread 12-07-2011, 09:02 PM
Sorry Dan! I looked all through my extra parts stash and couldn't find one. I have all the parts to make a spare clutch assembly but no washers at all. I can't recall fooling around with those washers before either.. I wonder if mine are even in my Honda.
Unread 12-08-2011, 01:08 PM
Default Clutch washer from ATV-parts
No luck. They don't have it in stock. I've tried several other places but no luck there either. Thanks for the leads.
Unread 12-09-2011, 07:35 AM
Default Found the washer
Found the part in New Jersey,
Great people to work with.
Thanks for the help guys.
Bergen Sport Cycles
http://bergensportcycle.com/
