CA92/CA95 Clutch thrust washer
I'm looking for a CA92/CA95 washer C, thrust 20mm
PN C902878 or 90453-200-000 It is supposed to be installed between the outer and center clutch. It's in the parts book page 54 as item #13. Does any one have the part to sell me? Is it ok to install a standard washer? If so what is the thickness of the washer? Dan U |
I'll check in the morning and see what I have.
Sorry Dan! I looked all through my extra parts stash and couldn't find one. I have all the parts to make a spare clutch assembly but no washers at all. I can't recall fooling around with those washers before either.. I wonder if mine are even in my Honda. :)
Clutch washer from ATV-parts
No luck. They don't have it in stock. I've tried several other places but no luck there either. Thanks for the leads.
Found the washer
Found the part in New Jersey,
Great people to work with. Thanks for the help guys. Bergen Sport Cycles http://bergensportcycle.com/ |
