C95 headlight
weestrom05
C95 headlight
Can i replace the sealed beam light on my ca95 with the light out of a c95. The bulbs for the c95 are readly available and it seems to be a better choice than the plastic unit from Thailand?
I believe they are identical. I am working on an option to use the 6-36v LED bulb off of ebay. Cut out the sealed beam bulb, then use a grommet to hold the new bulb in. The active heatsink takes up quite a bit of room. I'll post on the headlight thread when I get it worked out. If possible.
My other option is to find an auto headlight at the junk yard with an H4, cut out and glue on the adapter and use the 6v 25/25w halogen off of ebay
