Carb Rebuild Kits
Carb Rebuild Kits
Where would be the best place to get these for the 160?
Interestingly enough Honda doesn't offer "kits". They sell the individual pieces, if you can get them. So that means the aftermarket and usually eBay. The ones from Canada are ok. Generally, often jets are not the correct ones in the kits I've seen and some kits you don't get everything, the bowl gasket hangs the float etc.
In my opinion most jets and orfices, unless corroded or drilled to an unknown size, are reusable, so I clean and save them. I use the manual as a base line for jet sizes but I'm at sea level so things don't change much from stock jetting.
