Bike Overheating?
scott12544
Bike Overheating?
Hi guys, here is my issue. The bike runs awesome and idels great for the first 10 miniutes of riding it. However after a while when I pull up to a light it does not want to idle. sometimes I pull up to light and it is ideling high then works itself back down to a normal idel then gets slower and slower and eventually dies. I have to keep reving it to keep it running. I have the mix screw out 1 1/4 and I have the clip in the middle position on the needle in the slide. Is it running to lean or rich or is it overheating?
scott12544
could the jets be getting bigger from the heat...creating a rich running condition. just trying to figure it out. It is definately do to the heat because it runs great when it initally warms up..I am gonna stop at harbor freight and buy one of those laser thermometers and see what kind of readings I get when it starts idling weird....
scott12544
scott12544
yeah here is the coil i got..http://www.bikebandit.com/emgo-points-s ... 958...keep the ideas comming...
Thanks, Scott
Thanks, Scott
scott12544
scott12544
I agree, it sounds heat-related.
If the carb is getting too hot, the gasoline will expand, which could provide an overly-rich mixture, especially if the float setting is high. Has the float setting been changed?
Have you pulled the spark plugs for inspection after the symptoms appear? There could be some good clues there. I'm wondering if the plugs have a sooty black surface.
When the engine starts acting up after 10 minutes, are there other symptoms, like blue smoke?
After the symptoms appear and you have to increase the throttle to keep it running, is it running smooth at those higher RPMs or is it coughing or acting up?
scott12544
ok checked out the spark plugs and the plugs they were heat range of 5, I ran down to napa and picked up some dh8a's (after checking the forum)....with heat range of 5 versus 8 really cool down the bike as much as 20 degrees. When i was putting the bike together I just replaced the plugs with what was in their, thinking whoever had it would of ran the right plugs... I ran the bike again with new plugs to get it back up to temperature and it appears to be running better, but of course it got cooler out so that may have something to do with it .... The bike always ran well at high rpm, and I have never seen any smoke really at all since having the head rebuilt...also on my way home while at a light I felt the carb and it wasnt really hot just warm...I think now it was the plugs...anybody else had the same situation?
Jetblackchemist
It might be an idea to get in touch with a Auto electrition and ask what the implications are of running a 12v coil in a 6v system.
Also, using the wrong plugs coupled to the wrong plug caps can cause all sorts of problems, like the plugs, not all plug caps are compatable. (resistor/none resistor)
scott12544
Sam I am running a 12v system. 12v battery, silicon rectifier (ohio cycle), and now the 12v coil. I was using the stock coil but the bike idles better with the 12v coil. I think the stock coil was a little tired.
Jetblack, I cant really back the mix screw out much more with out it being too loose. The plugs were a little sooty. I could drop the needle down a notch and see how it runs. I would think a lean mixture would make a the bike run hotter and rich just dirty..
I broke the clutch cable so I could not ride the bike to work today. I will fix when I get home tonight and report back tomorrow on how it runs with the new plugs.
scott12544
Jetblackchemist
