Thank You ByTheLake, Puzzleparadise, and Spokes
For your help today. Spokes, you nailed it. My points lobe was 180 off. After I got it back together it started right up and ran great! I am grateful for the tutoring you guys have given me over the past couple months. The other day ByTheLake told me exactly how to go about tracking down my no spark problem. I learned how the electrical system works and I got some good practice in with my test light and continuity tester. Now I am going to go through the rest of the electrical and get it working.
And Spokes:
Today, I thought I was going to have to redo the timing again. I had just spent a good part of yesterday doing that because I was one tooth off, I had the cam running one tooth early. I sure am glad I mentioned the fire today and I sure am glad that you told me about the points lobe!
Since I seemed to be having so much trouble getting the crank and cam in sync, I checked my cam timing today before I got the engine all back together. Once I got the cam chain reinstalled I went ahead and put the dynamo (alternator?) housing back on the engine. Then I put the flywheel on so I could bring the flywheel T mark around to the screw that the pointer is mounted on. Then I checked the cam position. It only took me a few minutes to check my work that way and possibly having to redo the timing again.
Thanks Again!
Steve
