Could anyone help me out with a full tut on how to clean out the fuel system on a 67 touring.
I bought the bike. Ran beautifully. Filled it up with gas, and it choked on some rust that was at the top of the tank. Cleaned out the filter at the petcock and she started right up again.
This time, cleaned out the filter (need to replace the wire mesh filter), but that didnt do the trick.
How would I go about cleaning all rust that could be clogging the fuel system and not allowing the bike to start. Top to bottom clean out.
Thanks a billion and a half!
Doug "I wanna get my OBH running" Hansen
67 Touring: Fuel issue
Be aware that chemically cleaning the tank could open rust pits into holes.
Protect the paint with a light coating of grease or Vasoline.
Chemical. Citric acid works best and is the friendliest to work with. Drain the tank and remove it from the bike. Remove the petcock(you will need a new "O" ring.
Wash the tank out, I like Westleys White Wall cleaner..
Fill the tank with Hot water...hotter the better. Add a 1/4 lb of citric acid (granulated, found on eBay) Mix and allow to sit for 6-12 hrs.
Repeat wash, dry..then
Buy a package of BB's. Block all holes after adding the BB's to the tank. Shake the tank violently, back & forth, up and down, right to left, about 10 minutes. Drain out the BB's, rewash and allow to dry. Reassemble.
Or
hosphoric Acid. Same hot water, 30 minutes. Be carefull. Phos burns.
Or:Caswell makes a tank sealer that some forum members swear by.
Or: Wash the tank out as above. Just do the BB's.
Or
