1960 Rebuild
pmannfury
1960 Rebuild
Post by pmannfury »
Been reading and enjoying the posts in this forum for over a year and now I'm going to have to ask for some help. I'm restoring a 1960 CA95 that was my grandfathers and have just started reassembling everything. I got it in parts so am not sure how everything looked but luckily he had a service manual that provided a lot of guidance. The two problems I'm having now is mounting the engine to the frame and cable routing. I think the engine has three bolts that connect it to the frame two shorter towards the top and a longer one at the bottom. Is this correct? If anyone could provide a picture of the bolts to make sure I am using the correct ones I would appreciate it. I've looked through diagrams and read through the documentation but can not find those bolts. The other question is the correct running of the clutch, throttle, and brake cables. These are not mentioned either and I would like to get them correct if possible. I know it is not that important but these things tend to nag at me. Thanks for all the help and I look forward to being able to post some pictures.
Sam Green
Post by Sam Green »
Hi Perry, Is your bike the tube or pressed steel handlebars model :) ?
In respect of the engine mounting bolts there are five.
The top one is a long through bolt and the four rear are short ones, one for each mounting point.
Good luck, Sam.
pmannfury
Post by pmannfury »
It's a tube so the horn and other electrics go through the handlebars. You're right I forgot about the long top bolt. So both mounts on the lower part of the bike have a bolt on either side. I am guessing all four are the same. Does anyone have a picture or measurement of those bolts?
Sam Green
Post by Sam Green »
Perry, if you don't get an answer, I'll check my parts book when I get home. (10 hours)
Sam :)
Sam Green
Post by Sam Green »
Perry, I just got a little shock. I would have said the 4 rear bolts were all the same but they are not.
3 are 10mm X 40mm part number 92000-10040
1 is 10mm X 45mm part number 92000-10045
pmannfury
Post by pmannfury »
Thanks Sam measuring and installing now.
