CA95/CA160/CA77 Fuel Petcock Replacement
I found this replacement fuel petcock on ebay. This will replace the old leaky original tank petcocks on the CA95/CA160/CA77 Dreams. I bought this one for my CA160. It saves me from welding a bung in a good tank and ruining the value of a solid Honda tank. The base is made of aluminum and can use the original or replacement screws
65ca95
Post by 65ca95 »
Did you find under CA95 parts? Looks like a harley evo petcock
Yes, it's a Harley petcock. I bought one awhile ago for a tank that I had a 14mm bung welded in the tank. I found it under search words "CA96 petcock" on ebay. $29.00 was a steal. He is selling just the base mount for $19.99
It beats trying to find a good original fuel petcock. The beauty of it is that the tank remains original if you should want to install the original style petcock.
65ca95
Post by 65ca95 »
Thanks for the heads up. Will check it out
gbaumgratz
Post by gbaumgratz »
That's so strange - it must be petcock week because I was just reading this as well:
http://www.honda305.com/forums/viewtopi ... ght=#14203
gbaumgratz
Oh, and this is an interesting article for anyone rebuilding the original:
http://www.examiner.com/classic-motorcy ... a-petcocks
In case you never considered the condition of the lever's mating surfaces to the gasket material he reminds everyone of this....
Sam Green
Post by Sam Green »
Spokes wrote:Yes, it's a Harley petcock.
Hey Chip, It'll make ya bike vibrate like fcuk. :D :D :D :D
Sam. ;)
Crap...my seals will leak oil as well! Ha!
I can't believe you're giving up on the Honda petcocks so easily! When I assembled my petcock with the rebuild kit inside I had to source an o-ring because I didn't trust that flat rubber washer that was provided in the rebuild kit. It leaked a tiny amount for a few hours but then stopped and has been holding ever since. I would think that Vaseline or dielectric grease (my new favorite substance) could help seal the innards. I do feel your pain though. The original petcock seems as it was intentionally designed to be difficult! I hope that bike stay together after the install. :eek:
