Where can I find an oil filter for my 1965 C95 Honda Dream? I recently bought this bike and will be replacing some gaskets this weekend and I cant find anyone or anywhere that has an oil filter?! any help will be appreciated!!
1965 C95 HOnda Benly "Oil Filter"
Poindexter
There are no "gaskets" but two large thin "O' rings. Usually the old ones can be reused. Prying off the cover plate can mare up the finish on the case so take time to remove it. Once you remove the oil filter cover plate you will see lots of hard sludge. The filter pulls out for cleaning (usually hard to do after years in the engine) or you can clean it in place. All of your oil goes through this "spinner" then recirculates. It is important to clean it once in a while.
Poindexter
Yes. It is not an item to be replaced(unless damaged). Just remove the 3 screws on the cover plate and clean out the inside. You can remove it to clean or leave it in place. The manual suggests cleaning every two months. This part and the magnet in the oil drain plug are the only fixtures that "clean" the oil.
I change the oil frequently in my restores are done, so the "oil filter" stays clean all of the time. Having said that, if you find slivers of metal on the oil drain magnet or in the filter it may indicate trouble ahead.
Poindexter
Poindexter
Cleaner?
Spokes. What do yOu suggest using when I clean the oil filter? I am hesitant to use anything that could damage any .. If any seals ate still in place. Brake cleaner? Carb cleaner? Gasoline?
Poindexter
I've been using 10-30w synthetic oil for years with great results. You'll find it makes shifting gears much smoother, but it may also leak a bit more if your seals and gaskets aren't sealing well.
Also, be careful when removing the little phillips head screws fom the oil filter, as they are very easy to strip. Use an exact fitting phillips driver and smack it with a hammer before attempting to loosen. Maybe even try to tightening it a bit to break it loose first. Spend 10 bucks and buy one of those multiple bit driver sets - you will use the others for different screws on the bike. A manual impact driver and one of those cheap butane torches is very handy to have as well in order to shock those stubborn fasteners into submission
Poindexter
Poindexter
