Just finished the restoration and everything has been running perfect. Tonight I went to ride and the starter wouldn't work. Not a click or anything. Had rode it last night and not a problem.
Checked the battery and it's charged. Lights work, horn works, it starts right up with the kick start but nothing on the starter switch.
Battery terminals are not corroded and the starter was recently taken apart and cleaned.
I'm thinking I have a loose wire somewhere or the solenoid went out.
Can someone recommend an easy way to isolate where the problem may lie using a multimeter?
Thanks in advance for your suggestions
