Unread 09-03-2015, 01:52 PM
Roberd42's Avatar
Roberd42 Roberd42 is offline
Default Handlebars
Would someone that has a ca95 stock handlebar around please measure the dimensions of the slot for the internal throttle slide? If you could note how far off the end of the bar and where the notch is for the holder that would be awesome. I have a drag bar I cut with a dremel based on my best guess. It works but is sloppy. So I got a correct length 2ft drag bar from eBay for a cb72 with holes cut for wires. I was going to use an external throttle from a cb72. Got that and the cable bumps the tank. So I have to go internal. I want to get this one right on the new bar.
Unread 09-03-2015, 05:26 PM
No Longer Available
Unread 09-03-2015, 08:05 PM
Roberd42's Avatar
Awesome! Thanks chip
