Unread 06-12-2012, 01:06 PM
Default Fuel line disconnect
Done.
Unread 06-12-2012, 01:55 PM
Puzzleparadise's Avatar
Awesome find..thanks for sharing, I ordered one right up..that'll make removing the tank so much easier!
Unread 06-13-2012, 01:45 AM
This quick disconnects are awesome.
Unread 06-13-2012, 06:03 PM
wnbasac wnbasac is offline
YUP i have these on my bikes both single and two way, they work great
Unread 06-14-2012, 03:32 AM
rhodemon rhodemon is offline
When removing my tank, I find it just as easy to suck all of the gas out using a Tempo oil changing unit. It holds about 2 gallons and has a bicycle type pump mounted on the top to create a vacuum. The unit comes with a bunch of different hose sizes and adaptors for various other jobs and is indispensable around the garage for all types of work like removal of gas for winter storage and changing lawn mower oil, etc. It also removes all of those annoying little particles that sit in the bottom of the tank and end up as trouble when they head toward your engine.
Unread 06-24-2012, 03:03 AM
Grunt Grunt is offline
Wouldn't I need two of these - one for each line coming out at the front of the tank or does it shut off both ends that are disconnected?
Unread 06-24-2012, 03:36 AM
Both sides shut off once disconnected...From what I understand
