Unread 05-15-2010, 08:48 PM
Default CA 95 Aftermarket Custom 6 Volt Turn Signals
Here are a few examples of the "Spokes" method of building turn signals for your CA95. This method works on CA & CB models 6 or 12Volt.
The external mounted switch (left or right hand)
A close up of a handlebar mounted signal
The front View
If you don't want to run the wires through the frame, you can make the rear fender brace a "conduit" This is a pic of a brace that is wired for signals and power for saddlebag lights.
This is where the "winker" goes
This is a pic of the rear signals mounted. These signals also mount with room for Buco Bag Mounts
Unread 05-16-2010, 11:19 AM
tuff cub tuff cub is offline
looks great! i'm so used to using hand signals from not having them on the benly, i've taken to just doing it on all my bikes. you've made a nice solution.
Unread 05-16-2010, 01:14 PM
aaron7 aaron7 is offline
Using hand signals and working the clutch is NOT easy!
Spokes, shoot me a PM when you get a chance.
