Unread 09-29-2015, 02:45 PM
rum-rum rum-rum is offline
Default Spark plugs
I just picked up 4 c10 h spark plugs.my manual read that these would fit my Honda benly.i guess my manual was wrong.the thread size is smaller,just goes to show you some manuals are not all correct.the plugs are brand new and in their own alluminum case and am guessing quite collectable so I guess I'll just stick them on the shelf.which plugs are you using in your Honda ...
Unread 09-30-2015, 09:09 AM
Nige1100s Nige1100s is offline
The UK C95 uses ngk D8HA.
NGK used a strange lettering system for the plug sizes
A is 18mm
B 14mm
C 10mm
D 12mm
Not sure how the worked that out.
The D8HA always come out a nice old fashioned mid brown colour. In a way that plugs don't on modern engines.
Unread 09-30-2015, 06:24 PM
Default Plugs
thanks for the reply nige1100 from jolly old England,will grab me a set.
Unread 10-02-2015, 07:51 AM
Michaelclark50 Michaelclark50 is offline
I ran into the same issue buying the c-10h's. They don't fit. My bike came with some D-9H's and that's what I bought to replace. I haven't started it yet but feel they are correct. PM me if you haven't bought any yet and I'll send you two of the D-9H's if you want. I have 8 left. That is 2 1/2 lifetime supply by my count. Assuming that is that a member who knows more tells us that is the wrong plug.
Unread 10-02-2015, 03:05 PM
Default Plugs
thanks for the generous offer on the plugs,I went down and picked up two NGOs hr8hs plugs and they work great,went for a twenty mile spin cruising about 50 mph,and all is good,ps I wish I could post pictures and a short video that I have....
Unread 10-05-2015, 10:45 PM
frappy's Avatar
frappy frappy is offline
The Honda CA95 Parts Manual lists the following plug sizes and part numbers: (Wow, what a range!)
(D9H), p/n 98066-58710
(D8HS), p/n 98066-58714
(D8HA), p/n 98066-58717
(D9H), p/n 98066-58717-00
(D10HS), p/n 98066-60710
(D10HS), p/n 98066-60714
Like Nige, I am successfully running NGK D8HA's in my '64 CA95 with a '63 motor.
