Unread 05-27-2015, 12:36 PM
NickyRudolph NickyRudolph is offline
Default Key fell out while riding!!!!
Today i took the bike out for a ride. While it had a multitude of problems, i kept going. Then i hit my first problem, when coming to a light i pulled in the clutch and the engine completley shut off. Any ideas why? Then i noticed the key was gone! But the ignition was still in the proper key stroke. It somehow fell out while riding. I can start the bike without the key because it is still on. Where can I go from here? Pre cut key? New ignition switch? Please help asap
Unread 05-27-2015, 03:30 PM
Roberd42's Avatar
Roberd42 Roberd42 is offline
Cheapest, easiest option is to get another key. Read the number off of the ignition face. I've got several keys for my bike, a couple originals and some cut to match. Mines an NA key, harder to find. Check eBay and this guy has a bunch of keys for $10: http://toronto.kijiji.ca/c-cars-vehi...AdIdZ314919148
Won't help with the key falling out though. Might need a new ignition. Personally, I'd run a screw somewhere and string it off so it won't be lost again. The idle cut out sounds in the carb. Is it clean, jetted and adjusted properly? Timing and points are set within spec I assume.
Unread 05-27-2015, 06:34 PM
If ignition is still "on" you will need to disconnect the battery pronto. If by chance the points are closed and the ignition is "on" without the engine running, you will cook the coil.
If You will know if the coil is cooked by drips of wax on the engine.
Unread 05-28-2015, 07:11 AM
I yanked the fuse. If I get a key with those same numbers it will be compatible?
Unread 05-28-2015, 08:56 AM
Default Key compatibility
Most of the time the will interchange. On my 62 there is two different groove patterns. The first one i ordered did not fit. Curt
Unread 05-28-2015, 02:06 PM
Roberd42's Avatar
Typically those numbers mark the key pattern. So it should be plug and play. Didn't have any problem with the two NA keys I ordered.
Unread 06-09-2015, 10:04 AM
I've got my new key, but being that the ignition switch is still turned to on, I can't just put it in. What should I do
Unread 06-09-2015, 12:08 PM
Roberd42's Avatar
Oh buddy. I don't know. So it didn't lock the key and it fell out but now it's locked ?? Crazy! Maybe chip can chime in. I'm not sure if he's been into these ignitions.
Unread 06-09-2015, 01:47 PM
Yea, I've rebuilt several CA95 ignition switches.
Something is very screwy about this key/ignition problem. It sounds like part of the old key is still in the tumbler. Or the tumbler is damaged.
Unread 06-09-2015, 09:35 PM
I doubt the old key broke. Maybe a bad tumbler. Any ideas? The key I have is na4064 any help is much appreciated
Unread 06-10-2015, 02:38 AM
I assume the key number matches the tumbler number.
If so, the key should slide into the switch easily. You need to shine a bright light into the key slot under magnification and look for any obstruction or damage.
The tumbler could be trashed.
It may be easier to replace the switch.
Unread 06-10-2015, 03:09 PM
Pins were still locked, flat screw driver did the trick. Turned it to off, put new key in, no problems! Any idea why it stalls sometimes when I pull in clutch
Unread 06-10-2015, 05:13 PM
Idle speed too low. Timing off, float not adjusted, low cylinder compression,
That's the last of my guesses. Good Luck
