Unread 07-30-2012, 06:37 PM
1911tex 1911tex is offline
Default Carb idle air mixture question >>>
The manual states...screw in > Rich; out> lean.
I screwed it in rich until the engine lost a few rpm, then out 1/2 turn. Is this correct?
The other option would be to screw out lean until engine loses rpm, then in 1/2 turn or so.
Thoughts? Appreciate all!
Unread 07-30-2012, 07:19 PM
Basically, I adjust idle to whatever I feel is a good idle. I turn out the screw until nearly stall and then screw in until I like the idle. I don't think there is a hard fast rule.
Unread 07-31-2012, 04:55 AM
I'd agree with Spokes( who wouldn't). Heck my mixture screw is so loose the idle changes if it sits and vibrates too long.
Unread 07-31-2012, 05:36 AM
Spokes: Thx again.
Larzfromarz: Wrap teflon thread sealant tape around the air screw; enough to tighten it up.
