Unread 07-28-2011, 10:43 AM
Default "Round Bowl" Carb Gaskets
Hello fellow enthusiasts!
I was wondering if anyone had found a source for float bowl gaskets for the earlier ca95. I have a '62, and the rebuild kits only include gaskets for the squared-off float bowl. I have the original, but I'm getting a bit of seepage from the bowl.
Unread 07-28-2011, 02:02 PM
The best thing to do is have a gasket made, or make one for your carb. The rebuild kits I have seen are for the rectangle type floats.
Unread 07-29-2011, 05:00 AM
Go to your local auto parts store and pickup a sheet of Fel-Pro rubber & cork gasket material and make you own . Easy and inexpensive and you'll have gasket material for other projects .
