Page 1 of 2
CA95 Rear Shock Auction
Posted: Sun Apr 25, 2010 7:46 pm
by gbaumgratz
Seems like someone got a decent deal since no one else was paying attention. I forgot to follow up... figures.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AUS%3A1123
Mine are pretty rusty compared to those. Does anyone have any information as to how to take the covers off of these? Maybe I'll sand down the chrome/rust area and paint them black until I can find better ones. Anyone have any better ideas?
Posted: Sun Apr 25, 2010 8:57 pm
Here is how to do it.
Mount the shock in a vice
Here are the tools needed. 1. A strong scraper 2.) an automotive grade tubing spreader 3.) A 17mm wrench 4.) A Vice
Pry the base from the mount
Slip in the tubing spreader and the 17mm Wrench. The inside "nut" has only two flat sides.
Insert an 1/2 "extension bar through the top of the shock mount-make sure to remove the rubber bushings first. Hold the wrench tight and unscrew the top
With the top mount off, you will see a stud with a screw slot. Some older shocks may not have a slot. Use a Dremel tool with a grinding disk to cut a slot. It makes it easier to get the nut off. Sometimes the nut will just turn off without having to hold the stem...but usually having or cutting in a slot makes it easier.
Unscrew the nut
The spring tension in very little. Once the nut is removed the spring just slips up and away. The lower case is now loose and can be removed.
Done
Posted: Sun Apr 25, 2010 11:04 pm
Nice pictures. Makes me want to take my spare ones apart and mess around with them.
Posted: Thu Apr 29, 2010 6:56 pm
There is another set of shocks on ebay for the CA95 & 160. They are pretty clean, not perfect but very usable. They can be easily disassembled for chrome as well. The mounts have been polished and the rubber grommets good.
I know. I built them out of clean spare parts.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ESELX%3AIT
Posted: Thu Apr 29, 2010 7:42 pm
To add a link in you forum post here just highlight the address of the web address in the Ebay window - then press "control + C" to store it in your computers temporary memory. Then press "control + V" to make it paste into your forum post here like magic.
If you want to make it the color blue which automatically makes a persons window open that link in a new window when they click on it - click on the icon that looks like a little globe with a chain link in front of it. Then paste the web address in the window that will pop up when you click on the globe icon. Give it a try.
Posted: Thu Apr 29, 2010 8:00 pm
Thanks! You can still train old dogs new tricks! Done and corrected.
Posted: Fri Apr 30, 2010 5:42 am
by Brewster
Spokes those are nice. I dont really see any flaws other than they are 40 years old. To find flawless is rare and not expected where I come from.
The ebay funds are low for me right now otherwise I would be bidding.
Posted: Fri Apr 30, 2010 6:09 am
I guess your right. I tend to be a perfectionest. The plastic tops were scratched upon reassembly, but just the surface and on the inside. The chrome bottoms had rust but no dents. No flake of the chrome. The outside of one is almost new. The mounts were polished and look nice. One bottom mount has some rash.
I am restoring a set for another member, new chromed bottoms, painted tops and mirror shine mounts. Those will be perfect.
Next time I will alert the forum members before ebay.
Posted: Sat May 01, 2010 7:37 pm
by hoghungry1
I was at a swap in Canfield Ohio this weekend . Picked up some shocks from these guys building mini choppers in a rigid frame. I will post pics but I think these would be a cool replacement if we can just find who made them. They are an exposed shock with what looks like the proper mounts. I have no idea if they fit yet but the guy practically give them to me!
They are aquiring them somehow with the kit they build from and tossing them. Interesting as hell. Will report back later...
Posted: Sat May 01, 2010 9:47 pm
by tuff cub
thanks for the how-to photos- i'd been wondering how that assembly works.
Posted: Sun May 02, 2010 10:10 am
Yeah this is some good info for sure. They did a good job designing these shocks so that they are tricky to take apart.
Posted: Sun May 02, 2010 10:47 am
by hoghungry1
Hey- for future reference. I passed on a 300 Dream shock fer 15 bucks. Should I have grabbed it for parts or trading stock? It was in good shape no rust.....
Spokes will probably be mad at me fer passing it up with all his rebuilding wizardry on our shocks...
Posted: Mon May 03, 2010 7:55 pm
by gbaumgratz
Definitely good info for when I get to the tear down stage - thanks for posting the detailed process. Are you offering up services on the shock rebuilds? Do you have a source for the replating of the chrome parts or are you doing it yourself there? Maybe an offline conversation could be had?
Posted: Mon May 03, 2010 8:32 pm
The shock rebuild is tricky. I am doing a set for another member of the forum. He has metal tops on his shocks. Repairing and painting the metal tops is always easy. The plastic tops are the ones that make or break the job. If the plastic tops are in good condition they can be painted or clear coated. If the plastic tops are damaged then expensive epoxy has to be used as adhesive and filler. Just the epoxy is $25.00. I send out the shock bottoms for chrome. That price depends on the condition of the metal, usually $25-$35.00 per base. I am still waiting on the return of the plated parts (3 weeks). The only thing I do (besides repairing the tops) is buffing the mounts to a near chrome shine. A bad set of CA95/160 shocks can cost close to $125.00(pair) to restore to new condition, paint, chrome, polish and labor.
You can pm me about more detail. The turn around time due to the long wait for chrome could be 4 weeks.
Posted: Thu Nov 24, 2011 10:25 pm
by bamabob
Spokes wrote:Here is how to do it.
(picture here)
(picture here)
(picture here)
(picture here)
Spread the mount from the base and locate the two flat sides.
(picture here)
Slip the 17mm open end wrench onto the flat sides of the shock mount base
(picture here)
(picture here)
(picture here)
The spring tension in very little. With a flat screwdriver screw the stud in until the the spring is released . Secure the wrench on the nut if the suud does not loosen easily . Sometimes the nuts are rusted bad and you may not be able to get them loose. Invert the assembly into a phosphoric acid bath or penetrating lube to help break the rust.
(picture here)
Once the spring is removed the base is released. Keep in mind that once in a while you can't get the assemble apart. So sometimes one fails.
Spokes, any chance of posting the pictures that go with this thread? Would be great to see how its done.
Bob
