Posted: Tue Apr 20, 2010 8:40 pm
by boy_uz
Picture for more...
-- Final image. "The measurement of heat" Temple of heat directly from the radiator.
And measure the heat from direct.
-- Measure and charge back the power of Matrix Partners.
** I use the English language. "If I use the language incorrectly sorry.
Posted: Wed Apr 21, 2010 8:49 am
Heat really isn't an issue. Just hook it up and run it. As long as you hook up some decent size radiator you won't have a problem. I don't even run the fan on mine. I will use a switch when I go off-road and in the sand.
Just use your Toyota radiator and you will not have a problem.
And use the spark plugs and spark plug wires that came with the engine.I returned the new spark plug wires to the store. I didn't use them. They were too short. The stock Lexus wires are just fine.
Posted: Wed Apr 21, 2010 8:51 am
Just connect the intake and use it. You just need to connect the AFM - Air Flow Meter and make it fit. My intake is different since I run a custom computer of course.
Posted: Wed Apr 21, 2010 7:39 pm
by boy_uz
enough to understand some.
>> Spark plug cable and set to use the Lexus for ??
- Set price and about how much
- I want to replace all 10 lines / interference advice.
-- Spark plug cable, the picture attached, or not available / price / set much.
Thank you very much.
