Thanks for all the replies, I will fine tune that throttle some more.
In the meantime, I'm having a heck of time trying to track down why the headlight wont come on.
The horn works, the brake lights work, the neutral light works.
Tested the headlight off the battery and it works.
Checked the grounds and they all seem to be fine.
I get 6.08 volts at the black wire that goes to the horn switch but nothing from the blue or the red wire.
Seems to me the black wire feeding the horn switch would carry the power for the horn and headlight (blue and red - high/low)
Otherwise how does power get fed to the headlight?
Here's a picture to help show what I'm talking about and also a picture of the switch when I was taking it apart for cleaning.
The black wire feeding power to the neutral light has a white stripe on it which is different that the plain black wire for the horn.
What do you guys think?
My light switch is a two (2) position switch and nothing happens in either position.
One more easy question for you guys.... is this fuel line connector just a press-in fit to the petcock? Should I JB weld it?
Thank you for all the replies and recommendations. You guys have been so helpful!
