Help.....ca160
The old black horse
Awesome! Make it like you want to make it. It's a great engine but it's all 6 Volt so it might be a little tricky to do things with the electrical... nothing you can't figure out. The rectifiers are pretty good so I wouldn't do anything to it. All the rectifier does is convert AC current into DC so it won't need to be updated in any way. If you want to do turn signals I recommend buying regular turn signals and just finding some 6V bulbs to go into them. Easy stuff I'm sure you know.
Save the handlebars and the seat! You can sell them to help pay for your new mods. I can't wait to see some pictures of it. How many miles?
You NEED to find a Honda CA160 manual for your engine build. There is a lot going on in there and the service manuals are simply amazing. They explain every single detail of the bike, the engine, the wiring harness.... You can EASILY get them for under $20 US. You will have a great time reading the vintage manual. They are so much better than what they have today. They explain the functions of components like condensers, regulators, rectifier etc. You will not regret buying a manual!
WOW that's like new! It should be in perfect running condition then. Pictures!
And what area do you live in? I can't assume anything cause lots of people chime in from around the world about Hondas...
Great to hear there was minimal damage. These bikes start up very easily. It's common that these bikes were set aside because of a problem and then never fixed and used again. I got one of my Hondas because the shifting rod that actuates the clutch was bent, thus, unrideable. It was a good thing because it had a hard life and if they fixed it I'm sure the owner would have run it into the ground and threw it away.
Sounds like the paint damage is also minimal as well.
