Key fell out while riding!!!!
NickyRudolph
Today i took the bike out for a ride. While it had a multitude of problems, i kept going. Then i hit my first problem, when coming to a light i pulled in the clutch and the engine completley shut off. Any ideas why? Then i noticed the key was gone! But the ignition was still in the proper key stroke. It somehow fell out while riding. I can start the bike without the key because it is still on. Where can I go from here? Pre cut key? New ignition switch? Please help asap
Cheapest, easiest option is to get another key. Read the number off of the ignition face. I've got several keys for my bike, a couple originals and some cut to match. Mines an NA key, harder to find. Check eBay and this guy has a bunch of keys for $10: http://toronto.kijiji.ca/c-cars-vehicle ... Z314919148
Won't help with the key falling out though. Might need a new ignition. Personally, I'd run a screw somewhere and string it off so it won't be lost again. The idle cut out sounds in the carb. Is it clean, jetted and adjusted properly? Timing and points are set within spec I assume.
NickyRudolph
Spokes wrote:If ignition is still "on" you will need to disconnect the battery pronto. If by chance the points are closed and the ignition is "on" without the engine running, you will cook the coil.
If You will know if the coil is cooked by drips of wax on the engine.
I yanked the fuse. If I get a key with those same numbers it will be compatible?
weestrom05
Key compatibility
Most of the time the will interchange. On my 62 there is two different groove patterns. The first one i ordered did not fit. Curt
NickyRudolph
NickyRudolph
Spokes wrote:Yea, I've rebuilt several CA95 ignition switches.
Something is very screwy about this key/ignition problem. It sounds like part of the old key is still in the tumbler. Or the tumbler is damaged.
I doubt the old key broke. Maybe a bad tumbler. Any ideas? The key I have is na4064 any help is much appreciated
NickyRudolph
