Unread 08-29-2012, 10:23 PM
Done.
Unread 08-30-2012, 12:09 AM
Originally Posted by Jetblackchemist View Post
It's like trying to pour something from one container to another...with a funnel, it's more efficient to get fluid in pouring into the large end of the funnel out of the smaller into the container, than it is flipping that funnel over.
Great analogy, it illustrates the point well. I've been getting interested in carburetor theory lately with my carb-swapping my first 2-stroke - fitting the little bugger is quite the adventure.
Unread 08-30-2012, 01:43 PM
grubsie grubsie is offline
Has anyone actually used an aftermarket carb successfully? I would like to know which one and how they went about jetting it. I know I am in the CA95 thread, but I have a CA160 with the air adjustment screw broken off inside the hole and the tube that the fuel line goes on is leaking like a sieve. I can't find an original carb anywhere and would be thrilled if I could get an aftermarket to work. Anybody ever try to drill out an air screw? Been able to do it successfully? Suggestions to stop the leak on the inlet tube? It leaks out around tube and the opening it goes into on the carb.
Unread 08-30-2012, 02:01 PM
If it is a press-fit brass fuel inlet, you might have luck with a gas-resistant adhesive.
Unread 08-30-2012, 10:35 PM
2 Part gas tank expoxy will work to seal the gas inlet. The kind that comes in a tube in is like Plato when you mix it yourself in your hands. I have tried to drill out a air screw but I was not successful I ended up for ruining the carburetor
Unread 09-05-2012, 10:21 AM
Got the air screw out with a very small drill bit and a very small easy out. Now just have to find another air screw, spring and o-ring for it.
Now, on to the leaky inlet tube.
Unread 09-05-2012, 10:48 PM
Done.
Unread 09-06-2012, 08:44 AM
Thanks Jetblackchemist, Already ordered the new parts from thumpertalk.com. Should have in a few days.
