Go Back   FourWheelForum > Tools, Electronics & Stereo Stuff > Restoration & Fabrication Techniques
Restoration & Fabrication Techniques Doing things right the first time.
Unread 07-04-2010, 07:15 PM
Default Removing Wheel Bearings From The Honda CA95 or CA160 Wheel Hub
Explained below is a quick and inexpensive method of removing the wheel bearings from the Honda CA95 & CA160 wheel hubs. This method can also be used to remove wheel bearings from a blind hub on most any application.
Below for example is the front wheel from my 1968 Honda CA160.
From your local hardware store, purchase a 3/8" concrete anchor as below
Place the anchor in the bearing bore
Secure the anchor with pliers and begin to tighten the nut to expand the anchor in the bearing bore. Snug to tight. No need to overtighten.
Place a sutable drift pin or the axle through the axle bore on the other side of the hub
Lightly tap with hammer
Until the bearing is removed
Remove the axle sleeve
On the front wheel of the CA model Honda remove the speedometer drive that is mounted on the hub. For the rear wheel or models without a fixed componant in the hub, just repeat the steps above
To drive out the opposite bearing in the hub, use a suitable drift pin or homemade brass tool like mine.
