Unread 12-29-2013, 04:31 PM
kirkdob kirkdob is offline
Default Sticking clutch solution
I have always had trouble getting my clutch plates to release after sitting for a while. The bike is very low miles, under 3000. In the past I have ridden around the block holding in the clutch while jabbing the throttle and the rear brake or doing the same on the center stand. I hated the process. Today I tried something that worked perfectly. I started up the bike, took a shop rag and tied the clutch lever in the fully released position while the bike warmed up. I slipped it into gear and voila!! No stall or jerk at all.
Unread 06-15-2014, 04:53 PM
sector160 sector160 is offline
Default stiking cluth
I allways keep the cluth released with a bolt or pencil at the lever end
Unread 06-16-2014, 04:46 PM
Do you mean always while the bike is stored or when warming it up? Having it parked or stored the the clutch always released would weaken the springs unnecessarily.
