Re-Chroming
Getting ready to have parts on my '63 re-chromed. Do you guys bring stuff to someone local or do you you send out somewhere? As usual, want a good job but do not not want to spend more than I have to.
Also, should any rusted parts need to be sanded first or will the re-chroming take care of it? 1 other question...how do you get the carburetor body looking like new again? I scrubbed mine in cleaner and used some brass wire brushes on it. It came pretty clean, way cleaner than it was, but still has stains in the aluminum. Do I need to remove everything off/out of the carb and soak it in something? Thanks Last edited by grubsie; 09-01-2012 at 08:43 AM. |
What parts are you re-chroming vs. polishing?
Exhaust headers and mufflers. gas tanks sides & cap, shifter, and lower fork covers. They all have little rust pits in them, The right muffler has battery acid stains and the headers are blued. Hopefully the headers won't blue out again.
Done.
The few chrome plating shops I talked with last year wouldn't accept exhaust pieces or rims. After some time my strategy shifted from plating to replacing the parts, but I did save the originals.
I use a local plating shop in Florida: Space Coast Plating. They're pretty well known and do some of the best chrome work I've seen. Always show quality but always pricey. As far as pitted items go, they do in house repair with a process of copper plating and polishing to fill pits, followed by nickel plating and polishing to give a proper surface for the final chrome plate. As the melting point of copper is much lower than the steel used in exhaust parts, the copper process isnt possible on those types of parts(headers, mufflers). Whatever steel is there is all you have to work with, and most of the surface imperfections will inevitably show through in the chrome. Anything else is fair game, I had a pair of shock covers that looked like Swiss-cheese and after plating they're heavier, thicker and better than factory chrome.
Found a guy in my area, NH, that will re-chrome anything I want. Going to give him a shot at a few things first.
Jetblackchemist, thanks for the tip. I just put the parts in the Pinesol soak. Can't wait to see the change. Do you think it would work on cylinder heads and engine cases also? |
It doesn't have to stay hot, you can re-use it until it stops working, and if you have one you can also feed it to a parts washer. |
Done.
Tried the pinesol soak. Threw all the carbs parts except for the rubber in the bucket. All loose parts, rinsed them under hot water and they came out squeaky clean. However the carb bodies were a different story. The yellow brownish stains came off beautifully, but now there is a dark gray areas/film? (for lack of a better description) on various sections of the bodies. I thought maybe that is was just wet in porous areas of the aluminum so I let them dry overnight to see if things would change. No luck. I then tried parts cleaner on them and that did not work either.
So, I think I am going to try the Gunk Hydro Seal. The dark gray color looks worse than the yellow brownish stains that were on the carbs previously. |
Not sure if its too late or not, but I got my carb nice and bright again by using Zing Formula IV Pontoon Boat cleaner. It comes in a spray bottle, so I just spritzed it all over my carbs then rinsed it off.
It's designed for cleaning aluminum pontoons, and it's strong stuff. I used it on my carbs because it was already on my shelf. You know you're using it correctly when your hands feel like a thousand ants are gnawing on them. |
