oem parts list
not all parts apply to dreams but if you see something Let Me Know
PART# & QTY / shipping is split > list is posted on other bike forums / i'll update list as parts sell > tks,lou Part # Qty Cost ea Description Cost all 11398-426-000 3 $6 oil pan gasket $ 16 15420-300-020 1 $7 oil filter bolt 154a1-413-505 1 $5 oil filter O-Ring 15410-426-010 3 $7 oil filter $ 18 17631-329-003 3 $2 gas cap packing $7 18291-mn5-650 4 all exhaust gasket $10 30201-003-004 1 $3 points base plate 30251-003-004 1 $8 condenser 30372-300-300 1 $4 point cover gasket 35317-001-310 1 both horn button All $ 11.00 35318-001-310 1 $11 horn spring spring 45105-ma5-305 2 $15 brake pads 45435-250-000 2 $2 frt brake spring 53161-250-000 2 $3 throttle wire hinge 53192-203-000 2 $7 cable adjuster 83650-003-000 2 $6 side cover latch bolt 87020-070-010 2 $20 fuel tank emblem 90407-259-000 5 $7.00 oil drain washer 90452-200-000 2 $2 washer B 20MM 91302-377-000 11 $4 oil filter bolt O-ring $ 26 91306-413-000 2 $4 oil filter gasket 91307-425-003 3 $3 oil stick cap O-Ring $ 8 91302-mg7-003 1 $3 oil pan O-Ring 91316-425-003 4 $4.00 oil filter case O-Ring $ 16 92800-12000 1 $5 drain bolt 94109-12000 11 $1.50 drain plug washer $ 11 95015-32001 4 $2 frt brake joint 95015-42000 4 $2 brake rod adj screw 98069-57911 4 $16 spark plugs 17620-402-010 1 $20 gas cap 32411-230-000 2 $5 starter cover boot 31201-292-158 1 all starter brushes 31204-292-158 2 $20 brush springs 31206-402-008 1 oil seal O-Ring 91012-202-010 1 $25 CA95 Bearing SCREWS & BOLTS 90114-310-000 4 $2.50 handle lever bolt $ 12 92101-060080a 8 $2 ea 6x8 hex bolt $ 14 92101-060160b 8 $2 ea 6x16 hex bolt $10 92101-060200a 6 $2 ea 6x20 hex bolt $ 10 92101-060250b 10 $2 ea 6x25 hex bolt $ 14 92101-060450a 2 $4 6x45 hex bolt 92101-080200a 6 $2 ea 8x20 hex bolt $8 92101-080250a 6 $2 ea 8x25 hex bolt $8 93500-04004-04 4 $6 4x4 pan screw 93500-05025-0b 12 $1.50 ea 5x25 pan screw $ 14 93500-050-080a 4 $3 5x8 pan screw 93500-050120a 8 $2 ea 5x12 pan screw $12 93500-050160b 6 $1.50 ea 5x16 pan screw $ 1.50 ea 93500-050200a 8 $12 5x20 pan screw $ 8 93500-050-220a4 $2 5x22 pan screw 93500-060120b 5 $10 6x12 pan screw 93500-060160a 6 $1.50 ea 6x16 pan screw $ 10 93500-060180a 4 $1.50 ea 6x18 pan screw $6 93500-060200a 5 $1.050 ea 6x20 pan screw $ 9 93500-060250a 6 $1.50 ea 6x25 pan screw $ 10 93500-060300a 5 $1.50 ea 6x30 pan screw $ 7 93500-060350a 10 $2 ea 6x35 pan screw $ 18 93500-060400a 6 $2 ea 6x40 pan screw $10 93500-06045-0a3 $2.50 ea 6x45 pan screw $6 93500-06060-0a3 $2.50 ea 6x60 pan screw $ 6 93500-060750a 3 $6 6x75 pan screw 94021-08020-0s 9 $2 ea 8MM acorn caps $ 15 94021-100200s 6 $3 10MM acron nuts 93700-030600a 19 $2 ea 3x60 oval screw $25 93700-05016-0a6 $2 ea 5x16 oval screw $ 10 93700-05030 6 $2 ea 5x30 oval screw $ 8 93700-060160a 8 $2 ea 6x16 oval screw $ 10 93700-060200a 16 $2 ea 6x20 oval screw $ 25 93700-060320b 4 $10 6x32 oval screw 96201-30001 9 $2 ea grease nipples $ 15 |
